This is a script command and operates only in scripts or on the command line when scripting is enabled with the following command: enable cli scripting {permanent}.
Deletes the variables that have been saved using a key.
key | Specifies that variables associated with the specified key must be deleted. |
N/A.
CLI scripting must be enabled to use this command. The user is responsible for generating unique keys for each variable. The system has a limited amount of memory to store these variables.
delete var key red
This command was first available in ExtremeXOS 11.6.
